  • 1756 Views
Resolved! STM32CubeIDE 1.9.0 H750VBT6 ADC fault
Was old project, works well, need make minor changes with not related to ADC functions, not look press "migrate" to latest version. was confused all ADC operations fault. when check what wrong, found ADC lost clocking.Take new computer, install clean...
AGord.2 by Associate II
  • 3123 Views
Timer 6 ISR utilizing 56-60% CPU (Threadx +STM32H7)
I am using stm32h7 with threadx where TIM6 is time timebase for HAL and systick is used by threadX. The project is generated using the standard cubeMX configuration. I am using tracelyzer to visualize my CPU utilization, and i found out that TIM6 ISR...
JTari.1 by Associate II
  • 2364 Views
SDMMC with SD card and NUCLEO-L476 not working
Hi everyone,I am having a hard time getting the SDMMC interface working with my NUCLEO-L476RG.I feel like this should be an out-of-the-box solution using CubeMX, but somehow I can't get it to work.I am getting a chip detect but an error when establis...
PSmol.1 by Associate II
  • 930 Views
Resolved! CubeMX Task Name Length
When I attempt to create a task with a name longer than 15 characters, CubeMX seems to truncate to 15 characters max. How do I name a Task in CubeMX longer than 15 characcters?
LMorr.3 by Senior II
  • 962 Views
Resolved! Is it possible for MX to set USE_HAL_ADC_REGISTER_CALLBACKS?
I need to use the ADC ISR to set a FreeRTOS semaphore. It seems that hadc1.ConvCpltCallback is the perfect feature to do this except it's not enabled unless USE_HAL_ADC_REGISTER_CALLBACKS is set. For the life of me I can't figure out how to make MX s...
RBack.1 by Senior
  • 1636 Views
Resolved! STM32 ADC DMA problems
I hope someone can help me with my problem. In a recent post I talked about my problems getting DMA work with the ADC. This does work, sort of.Now to my problem: The ADC is triggered by a timer update event. Then the data is transferred via DMA to a ...
0693W00000LyvckQAB.png 0693W00000LyvdEQAR.png 0693W00000LyvddQAB.png 0693W00000LyvdnQAB.png
Tim Goll by Associate II
  • 12036 Views
  • 11 replies
