  • 1756 Views
Generating an IOc file from stm32cubeide
Hi amazing communityI am working with the evaluation board stm32f429disco 1 (the new on with display)I am working on the usb host function to read a txt file and then making custom bootloader for a project .I have found this amazing demo project work...
SGasp.1 by Senior
  • 12976 Views
  • 4 kudos
SDIO 1 bit mode + FATFS not working with STM32L433RCT6
Hello Everyone, I am trying to run SDIO 1 bit mode with FATFS on a custom board but facing some issues.1)     CUBEMX Version -> 6.1.22)     API_VERSION -> STM32Cube_FW_L4_V1.16.0 3)     IDE STM32CubeIDE4) Schematic of SD card connection is attach...
pvish.13 by Associate
  • 2876 Views
Resolved! Inquiry about Boot Pin setting while using STM32CubeMX
I am using STM32CubeMX and need to setnBoot0, nBOOT0_SEL, and BOOT_LOCK. (Stm32G031 series is being used and Pattern 11 is being used)I have difficulty connecting with the STM32Cubeprogrammer program,so I would like to process it with the CubeMX prog...
Paul6 by Associate II
  • 2659 Views
Resolved! Nucleo-L476RG wrong I2C pins generated for I2C1?
Hi all,I'm starting to just get the hang of STM32 using a Nucleo-L476RG board.Discovering I2C, I'm finding the STM32CubeMX generates the I2C1's SDA/SDL pins for this board at PB7/PB6, not at all where they are according to the schematic (should be PB...
