wakeup from shutdown mode
Hi,why does the stm32l496 waking up from shutdown mode using syswkup2 pin and pullup. When I am using an external pullup resistor, the cpu stays in shutdown mode until I set a low signal on syswkup2 pin.best regardsJosef
josef2 by Associate II
  • 2727 Views
Black screen with STM32H7A3 LTDC
I have an STM32H7A3VI that I am using to drive a display.  The display is 24-bit RGB 1024x600 px:  https://download.riverdi.com/RVT70HSTFWN00/DS_RVT70HSTFWN00_Rev.1.2.pdf.  I'm not using TouchGFX or anything fancy, I just want a basic working example...
colin0325 by Associate II
  • 2161 Views
SysTick_Handler not called, STM32G070 (and 2024 release)
SysTick_Handler() function isn't called in a project based upon the STM32G070CB mcu (48 terminals). However, with the STM32G070RB (64 terminals (NUCLEO-G070RB)) there aren't any issues. I found this workaround from 3 years ago (almost 4):https://comm...
XR.1 by Senior
  • 2833 Views
I2C Communication with INA228 from Texas instrument
 Hello everyone, I'm interfacing an INA228  with an STM32 microcontroller  via the I2C bus. However, I'm facing a problem with the communication that I can't seem to resolve.Setup Details:Microcontroller: STM32h7 (using HAL library)INA228 connected v...
Mnfz by Associate II
  • 7104 Views
  • 13 replies
GPDMA GPIO Output Configuration issues
Hello I'm working with a nucleo u575zi-q board where i've to set many GPIO pins in a synchronos way using GPDMA. I've successfully used the DAC and DMA example in the IDE, but Igot stacked with the GPIO output. I followed the case posted here, triyed...
eosella by Associate II
  • 4270 Views
