Resolved! Documentation on CAN bus
Can anyone give a hint on where to look for proper documentation on CAN bus development? I see some primitive examples online, though there are a lot of moments that are not explained as they shouldFor example, CAN filtering and identificator masking...
Siemens by Associate
  • 3264 Views
  • 6 kudos
Resolved! STM32 Maximium Pin Voltage in Output Mode
Hello,we use the STM32G474 with a single supply voltage of 3V3 at the VDD Pins.At the moment we investigate defective microcontrollers. The Microcontrollers are defective after several hours with the 3V3 VDD voltage supplied. The defective is an incr...
QSPI reads only 0x9999
I have a custom board with STM32H747IGT6 MCU, which communicates with a S25HL512TFAMHI010 flash memory chip over QSPI. I have made several iterations of this board, and the QSPI communication has always been fine.However, on the most recent iteration...
Resolved! QSPI RAM on OSPI Interface of H7A3 MCU issues
Hi Guys,I need some help / input:I am trying to get the communication running between my Nucleo H7A3 and a Shield with a ISSI QuadSPI RAM in a SOP-8 Package running.Scenario:I am debugging with my Scope, I have a digital Probe on all 6 lines (CSn, Cl...
CBerg by Senior II
  • 3182 Views
Problem setting up UART on STM32F756VGH6
Hi,I am learning and exploring the STM32F756VGH6. My goal is to setup a simple UART and send some data to the PC using USB-UART serial converter and  puTTy terminal on PC. I am using register based coding approach as it makes the code more efficient....
Vilius by Associate III
  • 4375 Views
  • 10 replies
  • 5 kudos
