Corrupted data waveform in specific LTDC data lines
I am going to set up a RGB666 LCD with STN32F779 and Frame buffer in SDRAM. The problem I'm facing is that there are a series of parallel dark lines in the image.I first tested the SDRAM and the reading and writing is done correctly. Then I realized ...
Slh_4-1743094968002.png Slh_1-1743094374198.png Slh_2-1743094447545.png Slh_3-1743094558893.png
Slh by Senior
  • 1326 Views
Resolved! Standby mode on stmL433 drawing too much current
Hi   I have a a stm32L433 48 pin processor and trying to get it into low power. I am using the STLink-V3PWR module with stm32Cube Monitor Power module.   First of all I placed a known value resistor across the STLink-V3PWR to make sure it is reading ...
STM32C0 - use internal oscillators
Hi all,i have selected the MCU STM32C051G8GU6 as the main controller of the RFID system and i am trying to use the MCU without using any external crystals or oscillators, can anyone please guide me how to use the internal oscillators.Thanks in advanc...
Resolved! From power-on to GPIO settings 【STM32H743XGH6】
I would like to know the necessary operations and settings from power on to GPIO control.I have made a board using STM32H743XGH6.I want to set the GPIOs to turn on the LEDs, but it does not work.I am setting the GPIOs by manipulating the registers di...
NiM by Associate III
  • 1634 Views
  • 7 kudos
Unable to View Output from STM32 Board via Serial Port
Greeting Everyone,I am facing an issue with my STM32 board having STM32F103C8T6 as MCU, while trying to see a normal "Hello World" output. After debugging the board, I attempted to connect it to my PC via the serial port. To ensure proper communicati...
Ratul99 by Associate III
  • 10793 Views
  • 26 replies
  • 9 kudos
