Resolved! STM32h755ZI-Q Crashes on a particular code only
Hi Guys,I am recently facing a very rare problem on stm32 nucleo h755zi- q i am working with ltc6804ic for a BMS and am facing the following issue:Whenever i upload the code on the stm32 it crashes, and says no debung info available etc, after this i...
Resolved! CAN bit timing configuration for STM32 G4 series
Hello! I am using Zync SOC with STM 32 G4 series. I am targeting 1Mbps baud rate using CAN protocol. I am able to achieve 1Mbps using external loopback on STM. Can someone help me out with bit timing and prescaler values for STM 32 and Zync SOC
Resolved! stm32g0 lptim1 low power sleep
I want to use LPTIM1 of the STM32G0x1 to wake up the MCU, if it's not already awake, and start a DMA multichannel single conversion. I think I know how to do the DMA/ADC part after getting the ADC_MultiChannelSingleConversion example running; I'll th...
STM32L476RG Nucleo-64 SPI Transmission Problem
Hi, ı am trying to send some buffered data via SPI but it doesnt work. PA5-6-7 are automatically set by SPI and I also enabled PB6 for CS. Normally my algorithm needs to:1) Send 3 HF pulses to low and start interleaved ADC simultaneously.2) Take 1400...
Stm325 by Associate III
  • 812 Views
