Unable to download library from ST official website
I tried to download library from https://www.st.com.cn/zh/embedded-software/stsw-stm32054.html several times but failed.When I clicked download v3.5.0, nothing happened. By the way, we network is fine. Is it forbiden to download this version?
ca11ac by Associate
  • 462 Views
Resolved! NSSP mode - SPI
This is a question related to SPI communication.What is NSSP mode? What does it do?Also is there any documentation that explains all parameters in detail other than this
Resolved! Option Bytes changes does not work
HIUsing stm32f303veh6.Changed the option bytes with the CubeProgrammer. 2.20.0 to override the BOOT0 signal. ( its floating )nBOOT1 - > uncheckedBOOT_SEL -> unchecked I see that the address on start is 0x1FFFF.. and my FW on flash does not run. For d...
Rado1 by Associate II
  • 12051 Views
Resolved! SMPS on STM32N657
Hello,Regarding the STM32N657, I'm not using the internal SMPS.  My question is:  Do we need to put capacitors on the 6 VDDSMPS pins or can they be left as no connect?   Same question on the VLXSMPS pins... do we need the capacitors on these pins, or...
matt-crc by Senior III
  • 1120 Views
Resolved! STM32U031 freezing IWDG counter in STOP 0 mode.
Hello Everyone,I am facing an issue with my MCU entering low-power mode.My idea is to freeze the Independent Watchdog (IWDG) counter in STOP mode so that the MCU will not reset due to the IWDG counter elapsing.From my understanding, this can be achie...
