2025-10-28 5:25 AM
I'm trying to use 2 timers (TIM1, TIM8) in sync.
Everything works OK when using same value for both timers' ARR.
But drift occurs when using two different values as ARR (i.g. 3999 for TIM1 & 19999 for TIM8).
What could be causing this drift?
tim.c
/* TIM1 init function */
void MX_TIM1_Init(void)
/* USER CODE BEGIN TIM1_Init 0 */
/* USER CODE END TIM1_Init 0 */
LL_TIM_InitTypeDef TIM_InitStruct = {0};
LL_TIM_OC_InitTypeDef TIM_OC_InitStruct = {0};
LL_TIM_BDTR_InitTypeDef TIM_BDTRInitStruct = {0};
/* Peripheral clock enable */
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM1);
/* TIM1 interrupt Init */
NVIC_SetPriority(TIM1_UP_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
NVIC_EnableIRQ(TIM1_UP_IRQn);
/* USER CODE BEGIN TIM1_Init 1 */
/* USER CODE END TIM1_Init 1 */
TIM_InitStruct.Prescaler = 0;
TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
TIM_InitStruct.Autoreload = 3999;
TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
TIM_InitStruct.RepetitionCounter = 0;
LL_TIM_Init(TIM1, &TIM_InitStruct);
LL_TIM_DisableARRPreload(TIM1);
TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_FROZEN;
TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.CompareValue = 0;
TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
TIM_OC_InitStruct.OCNPolarity = LL_TIM_OCPOLARITY_HIGH;
TIM_OC_InitStruct.OCIdleState = LL_TIM_OCIDLESTATE_LOW;
TIM_OC_InitStruct.OCNIdleState = LL_TIM_OCIDLESTATE_LOW;
LL_TIM_OC_Init(TIM1, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
LL_TIM_OC_DisableFast(TIM1, LL_TIM_CHANNEL_CH1);
LL_TIM_SetTriggerOutput(TIM1, LL_TIM_TRGO_RESET);
LL_TIM_SetTriggerOutput2(TIM1, LL_TIM_TRGO2_RESET);
LL_TIM_DisableMasterSlaveMode(TIM1);
TIM_BDTRInitStruct.OSSRState = LL_TIM_OSSR_DISABLE;
TIM_BDTRInitStruct.OSSIState = LL_TIM_OSSI_DISABLE;
TIM_BDTRInitStruct.LockLevel = LL_TIM_LOCKLEVEL_OFF;
TIM_BDTRInitStruct.DeadTime = 0;
TIM_BDTRInitStruct.BreakState = LL_TIM_BREAK_DISABLE;
TIM_BDTRInitStruct.BreakPolarity = LL_TIM_BREAK_POLARITY_HIGH;
TIM_BDTRInitStruct.BreakFilter = LL_TIM_BREAK_FILTER_FDIV1;
TIM_BDTRInitStruct.BreakAFMode = LL_TIM_BREAK_AFMODE_INPUT;
TIM_BDTRInitStruct.Break2State = LL_TIM_BREAK2_DISABLE;
TIM_BDTRInitStruct.Break2Polarity = LL_TIM_BREAK2_POLARITY_HIGH;
TIM_BDTRInitStruct.Break2Filter = LL_TIM_BREAK2_FILTER_FDIV1;
TIM_BDTRInitStruct.Break2AFMode = LL_TIM_BREAK_AFMODE_INPUT;
TIM_BDTRInitStruct.AutomaticOutput = LL_TIM_AUTOMATICOUTPUT_DISABLE;
LL_TIM_BDTR_Init(TIM1, &TIM_BDTRInitStruct);
/* USER CODE BEGIN TIM1_Init 2 */
/* USER CODE END TIM1_Init 2 */
/* TIM8 init function */
void MX_TIM8_Init(void)
/* USER CODE BEGIN TIM8_Init 0 */
/* USER CODE END TIM8_Init 0 */
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM8);
/* TIM8 interrupt Init */
NVIC_SetPriority(TIM8_UP_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
NVIC_EnableIRQ(TIM8_UP_IRQn);
/* USER CODE BEGIN TIM8_Init 1 */
/* USER CODE END TIM8_Init 1 */
TIM_InitStruct.Autoreload = 19999;
LL_TIM_Init(TIM8, &TIM_InitStruct);
LL_TIM_DisableARRPreload(TIM8);
LL_TIM_OC_Init(TIM8, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
LL_TIM_OC_DisableFast(TIM8, LL_TIM_CHANNEL_CH1);
LL_TIM_SetTriggerOutput(TIM8, LL_TIM_TRGO_RESET);
LL_TIM_SetTriggerOutput2(TIM8, LL_TIM_TRGO2_RESET);
LL_TIM_DisableMasterSlaveMode(TIM8);
LL_TIM_BDTR_Init(TIM8, &TIM_BDTRInitStruct);
/* USER CODE BEGIN TIM8_Init 2 */
/* USER CODE END TIM8_Init 2 */
}stm32h5xx_it.c
/* USER CODE BEGIN PV */
volatile uint32_t TIM1Count = 0;
volatile uint32_t TIM8Count = 0;
volatile uint32_t TIMDiff = 0;
/* USER CODE END PV */
* @brief This function handles TIM1 Update interrupt.
void TIM1_UP_IRQHandler(void)
/* USER CODE BEGIN TIM1_UP_IRQn 0 */
if (LL_TIM_IsActiveFlag_UPDATE(TIM1)) {
LL_TIM_ClearFlag_UPDATE(TIM1);
TIM1Count += 5;
/* USER CODE END TIM1_UP_IRQn 0 */
/* USER CODE BEGIN TIM1_UP_IRQn 1 */
/* USER CODE END TIM1_UP_IRQn 1 */
* @brief This function handles TIM8 Update interrupt.
void TIM8_UP_IRQHandler(void)
/* USER CODE BEGIN TIM8_UP_IRQn 0 */
if (LL_TIM_IsActiveFlag_UPDATE(TIM8)) {
LL_TIM_ClearFlag_UPDATE(TIM8);
TIM8Count++;
TIMDiff = TIM1Count - TIM8Count; // <-- Diff increases
/* USER CODE END TIM8_UP_IRQn 0 */
/* USER CODE BEGIN TIM8_UP_IRQn 1 */
/* USER CODE END TIM8_UP_IRQn 1 */
2025-10-28 5:54 PM
There was a mistake when editing code snippet for upload.
Correct one would look like below as you suggested.
TIM1Count++;
TIM8Count += 5;
And the problem was that I was using TIM1 as center aligned mode 1 in the original code.
So using (Desired ARR - 1) as ARR for TIM1 was a critical mistake causing the drift.
Using (Desired ARR) as ARR for TIM1 and using (Desired ARR * 5 - 1) as ARR for TIM8 solved my problem.
Thank you!
2025-10-28 6:16 AM - edited 2025-10-28 6:16 AM
Should work unless interrupts are getting blocked.
What does your main.c look like? What other interrupts are active in the system and what are their priorities?
2025-10-28 8:14 AM - edited 2025-10-28 8:14 AM
You set TIM1's period to be 4000 clock periods and TIM8's period to be 20000 clock periods, so there are 5 TIM1 cycles in one TIM8 cycle; thus for one increment of TIM8Count, you increment TIM1Count by 5 * 5 = 25.
2025-10-28 5:54 PM
TIM1Count++;
TIM8Count += 5;
Thank you!
2025-10-29 1:25 AM
Thanks for explanation, but
this is why it's better to copy/paste code unedited. Or, even better, post a minimal but complete compilable code exhibiting the problem.
Glad you got it working.
