STM32 MCUs Motor control
GMA by ST Employee
  • 1838 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4992 Views
Zied b. by ST Employee
  • 9746 Views
Trouble with STEVAL-STSPIN3201
First, I am new to this board and to development using ST products.I have identified the STEVAL-STSPIN3201 as being the platform most suited to the project I am involved with and have attempted, unsuccessfully, to use ST Motor Control Workbench 6.1.1...
DHemb.1 by Associate II
  • 5805 Views
New B-G431b-esc1 ($AU3) can't connect with a CAN bus.
I have some drivers left from a few months ago, and they are working with no problem. This same project loaded to the new boards and everything works O'K except that the packets don't flow (neither way).I've tried to reset and set the CAN_SHDN (PC11)...
MSzym.1 by Associate II
  • 7079 Views
  • 10 replies
Hardfault problem
hi guys, have a good day,  i have a problem.i use stm32f303ret6 microcontrollermicrocontroller crashes to hardfault.As soon as the motor I control with a mosfet draws 3 amps of current, the microcontroller falls into a hard fault. It works when you d...
TB5BYO by Associate II
  • 2251 Views
Resolved! STEVAL_SPIN3202 inverter not working
Hello!I've recently started playing around with my new steval-spin3202 board. I've run into an issue, where the power MOSFETs of the inverter seem to not work.Firstly, I've left the hardware configuration default, so it is set up for six-step sensor-...
Kalamar1 by Associate II
  • 3005 Views
