2025-01-25 1:19 AM - last edited on 2025-01-25 1:49 AM by Andrew Neil
Hi
I need guidance on how to write the logic for interfacing the STM32F407 with the IIS3DWB vibration sensor after installing the X-CUBE-MEMS1 package and selecting SPI2 to generate the code.
2025-01-25 1:52 AM
Have you checked the documentation for X-CUBE-MEMS1 ?
https://www.st.com/en/embedded-software/x-cube-mems1.html#documentation
UM1859, Getting started with the X-CUBE-MEMS1 motion MEMS and environmental sensor software expansion for STM32Cube sounds like the place to start ...
2025-01-25 3:36 AM
2025-01-31 6:42 AM
Hello @Kumar123,
You can refer to the SPI_ACCEL_ComPolling example available in STM32CubeH7RS with the NUCLEO-H7S3L8. It may assist you in your implementation.
I hope my answer has helped you. When your question is answered, please select this topic as solution that answered you, it will help others find that answer faster.
Thanks for your contribution.
Dor_RH
