  • 1756 Views
[STM32CubeMX 6.14.1] text garbling
When I generated the source code with STM32CubeMX 6.14.1, my Japanese comments in USER CODE area are garbled. The character code is Shift_JIS. The version 6.12.1 is no problem.Could you please confirm and modify ASAP?
MTana.1 by Associate III
  • 4114 Views
Resolved! HSI16 and sysclock configuration using Cube
 Hello, I'm new to ST platform and I would like to understand about clock configuration.I'm using NUCLEOU545REQ board for my development and want to know how to enable HSI16 clock and configure system clock to 24Mhz using stm32cubeGUI.
HardFault_Handler when enable LWIP and touchgfx
Hello guys. I've bought Riverdi 12.1” board that mounts STM32H757XIH6. I developed graphic part and I use uSD, and USB Mass-Storage without any problems. I use FreeRTOS and FatFS. Now it's time to use Ethernet, so I bought PoE - Riverdi, enabled LWIP...
MauFanGilaMedical_0-1746012830072.png MauFanGilaMedical_1-1746012861994.png MauFanGilaMedical_2-1746012895732.png MauFanGilaMedical_3-1746012927438.png
CubeMX+SD card 4 bit+STM32F796 DISCO SD_FindSCR problem
HI All,I am using STM32F769 DISCO board.I have configured SD card in 1 bit moe and it works fine.But it doesn't work in 4 bit mode.The problem is in SD_FindSCR function.if(__HAL_SD_GET_FLAG(hsd, SDMMC_FLAG_RXDAVL))is never executed.Cube MX version is...
load2005 by Associate III
  • 1739 Views
