  • 1756 Views
Resolved! Running SDIO 4BIT wide mode
In this movie setup done  SDMMC 4BIT mode selected in CubeMX: Setup looks: In the older versions CubeMX like video before generated code for SDMMC or SDIO 4BIT setup looks like: That was confusing and doesn't really running SDIO/SDMMC in 4 bit wide m...
01 ST creating filesystem.jpg 02 OLD_CUBE_CODE.jpg 03 F746SDMMC setup.jpg 04 F746SDMMC code.jpg
wegi01 by Associate III
  • 2714 Views
Resolved! STM32CubeMX Version 6.14 Broke SAE Configuration
I just upgraded from version 6.13 to 6.14.  I have an exiting project for an STM32H7B3 that uses SAI1.  When I click the Generate Code button, I get the following warning:(The second warning is also a bug, I'm using CMake on my project so it is irrel...
cvanbeek_0-1741289131151.png cvanbeek_1-1741289475629.png cvanbeek_2-1741289559363.png
cvanbeek by Associate III
  • 1759 Views
EXAMPLE for H7R with bad .ioc
in LwIP_UDPTCP_Echo_Server_Netconn_RTOS example for H7S3, LwIP_UDPTCP_Echo_Server_Netconn_RTOS.ioc returns error Invalid State: Most probably trying to open 'LwIP_UDPTCP_Echo_Server_Netconn_RTOS.ioc' file from an abnomal previous IDE session exit. Pl...
mbarg.1 by Lead
  • 2337 Views
does stm32f103c8t6 support external loopback?
I wrote a code for this microcontroller to test the CAN protocol, and it worked successfully in loopback test mode—data was transmitted and received correctly without using any external CAN transceiver. Then, I switched the CAN mode from loopback to ...
Resolved! DFSDM filtre synchronization issue in CubeMX
  Moved from STM32H7B0 DFSDM Synchronization: Abnormal Clock Output During Register Configuration to a new thread in STM32CubeMX forum.   Thank you for your detailed instructions!I set a breakpoint as you suggested and found that the audio clock is ...
wenjing_0-1747380862890.png wenjing_1-1747381044407.png wenjing_2-1747381112081.png
wenjing by Associate II
  • 1918 Views
