  • 1756 Views
CubeMX install on Mac Sierra
Posted on December 06, 2016 at 09:52I am trying to install CubeMX 4.18.0 on my Mac (Sierra), opening the installer appears to do nothing, if launched via spotlight i get a warning stating unable to open the programm.#cubemx #macos #sierra
FREE_RTOS
Posted on May 24, 2018 at 12:53Hey,I am getting started with FreeRTOS on NUCLEO-FO72RB.i set UART communication using DMA.i would like to writre tu UART from muliple taske using queue with size of 16 items;so i created 3 tasks.- one task1 to receive...
C++ interrupts from cubeMX generated project
Posted on May 25, 2018 at 04:37I have discovered that renaming stm32f4xx_it.c to stm32f4xx_it.cpp in sw4stm32 causes interrupts to no longer work even after converting the project to C++.I have attached a minimum project for sw4stm32 that demonstrat...
Resolved! Generate conditional Init with CubeMX
Posted on May 22, 2018 at 21:29Hi,Is there a way to generate a condition inside the initialization code generated by CubeMx in TrueSTUDIO?I want to do something like this inside the MX_SPI2_Init() :    if (HAL_GPIO_ReadPin(GPIOI, GPIO_PIN_11) == GPI...
Bug On CubeMX 4.20.1? STM32F407 Triple Mode and DMA
Posted on April 07, 2017 at 16:53Hi all!I want to you use all of the ADC of the STM32F407VG in triple regular simultaneous mode and to save a buffer of samples in RAM with DMA.I configure everything with CubeMX and when I debug it, I cannot access m...
CubeMX generated code does not seem to compile in EWARM
Posted on January 25, 2018 at 12:27CubeMX 4.24.0 generated code does not seem to compile in EWARM 7.60.1.I am trying to create code to set up a STM32F071C8Tx.I get lots of errors relating to __DSB, __WFI, __WFE and __SEV saying cannot call intrinsic...
