2018-05-24 7:37 PM
I have discovered that renaming stm32f4xx_it.c to stm32f4xx_it.cpp in sw4stm32 causes interrupts to no longer work even after converting the project to C++.
I have attached a minimum project for sw4stm32 that demonstrates the problem Don't let the size fool you, there are around 5 lines of user generated code in there.
To build in C++, you need to exclude the .c version of the file (such as main.c) and rename it to have a .cpp extension in order to get everything to co-operate. I did this procedure with the stm32f4xx_it file, but no luck.
From my rudimentary understanding of how this programming stuff works, I believe that this is a problem with the linker. I'm just not sure how. The directories that these files are in are included by default, so they should build just fine as far as I understand.
#interrupts #c++ #sw4stm32 #cubemxWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
