STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Included path seems to not be included everywhere
Hi,I am working on a preexisting TouchGFX projects, and i am trying to make it multicore so i am trying to build with OpenAMP to test if i didn't tweak wrong settings in CubeMXI added the path in Project > Properties > C/C++ General > Preprocessor In...
Resolved! STM32CubeIDE / MX configuring octoSPI in multiplexed Mode
Hello,In my project, i am using 2 octoSPI devices connected to my STM32H735. (IDE is STM32CUbeIDE V1.19.0)After migrating the Project to STM32CubeMX 6.15.0 it is not possible to configure the octoSPI in Multiplexed Mode anymore. The existing config f...
AZorn.1 by Associate III
  • 1250 Views
Debug a software build outside STM32CubeIDE
I used STM32CubeIDE a long time ago but then switched to another IDE. Now for some reasons I try to use again STM32CubeIDE. I want to keep my build system (command line based on makefile and arm-none-gcc) and use the IDE only for debug. Environment i...
Gpeti by Senior II
  • 829 Views
Cube 2.0 multicore programming
HelloAfter upgrade STM32CubeIDE to 2.0.0 I have problem with programming multi core STM32WL55. Can download program to CM4 core, but not to CM0+. Before upgrading it worked OK. Now it generate message when programming CM0+: Erasing memory correspondi...
PitLab1 by Associate
  • 611 Views
