STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Command to send data from server to client in stm32WB
Hello I need send data from server to client, I did it, with the next command uint8_t data= 8; uint8_t *send_data= &data;P2PS_STM_App_Update_Char(P2P_NOTIFY_CHAR_UUID, send_data);But in "ST BLE Sensor" I can flash the lamp but can not receive value, ...
IRakh.1 by Associate III
  • 1775 Views
STM32WB do not print debug log in UART
The example project BLE_p2pServer ishas the debug interface configurated such as it is possible to see what is happening on the Wireless Stack.For example However if I use the project IOC file to make a new project I'm not getting any information.Act...
YGail.2 by Associate III
  • 1691 Views
How to add new sequencer
Hello everyone, I am working with 3 stm32wl55JC module. 1 is receiver the other 2 is transmitter. The code has UTIL_SEQ_RegTask((1 << CFG_SEQ_Task_Sensor_Process), 0, Sensor_Process);I want to add another task which needs to work as endless loop....
AHakk.1 by Associate III
  • 3900 Views
DMA A/D on STM32WB55 Nucleo board
Hello....I am trying to do a DMA of 32 samples every second. The A/D sequence is CH1, CH2. (so 16 samples of each). I have attached a picture trying to depict what I am doing. I am starting the DMA but I never get into the Transfer Complete interr...
SWenn.1 by Senior III
  • 4182 Views
