STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4119 Views
Resolved! implementing Nucleo Board examples in DK board
Hi I am new to the WBA series and am currently working with STM32WBA55G-DK1 board to implement the audio examples.I have a doubt, Can I implement my own custom profiles for sensor data transfer along with the audio, so that, when connected to an app,...
Pallavi by Associate III
  • 2374 Views
Resolved! Nucleo-WBA52CG issue after hard reset
Hi, I have a NUCLEO-WBA52CG dev board.I am seeing an issue whenever I do hard reset for the first time after power-on.After power-on my the loaded application works as expected, after a hard reset(using the button), the clock configuration seems to b...
Resolved! NUCLEO-WB55RG with BLE_HID_Mouse example not connecting.
After flashing NUCLEO-WB55RG board with the executable file from BLE_HID_Mouse examplecan't pair the board with the BLE of a computer. Add a device - does not see it!I have LMP 11.2292 - Bluetooth 5.2What should I do?Also, in BLE_HID mouse example RE...
GS2 by Senior II
  • 2963 Views
STM32WL with RGB, TIM16, PWM & DMA
Hello Everyone, I'm driving the WS2812 RGB-LED using TIM16 CH1.I have a very similar behavior as in this_post . The RGB works well just until MX_LoRaWAN_Process(void) then it doesn't work. I tried his solution but it didn't work(although I suspect th...
AElgh by Associate III
  • 2599 Views
Resolved! Audio example in Nucleo-WBA55CG
Hi @STTwo-32  @TDK @KDJEM.1 @Issamos @Remy ISSALYS ,I have started using Nucleo-WBA55CG for BLE Audio and realized STM32Cube_FW_WBA_V1.3.0 does not contain any audio code for the board. But STM32WBA55CG- DK1 has the ble audio snippet code.Can I use t...
  • 3673 Views
