2012-10-24 8:56 AM
We've managed to get our STM32F407 board to cycle in and out of standby using the RTC (once a second). We've also enabled the wake-up line to allow another low power micro to wake it up if needed.The problem we have at the moment, however, is that if the wake-up line is asserted just before the STM32 goes into standby the STM32 hangs, i.e. the RTC fails to wake-up the STM32 and the board needs to be power cycled before returning to normal.I've checked the errata sheet - but standby mode is not mentioned. Has anyone encountered a similar problem? Any ideas?Thanks #stm32-stm32f4-stm32f407-standby2012-10-26 12:33 AM
Any simple code to try?
JW2012-10-29 3:23 AM
I've found a similiar post with people having the same problem on the 10x and 20x STM32 processors. Here is the [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Leaving Standby by WakeUp pin and RTC Alarm¤tviews=192#{5D5CE2B2-A70E-4B62-BEB6-0EA6DE4CB220}&RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Leaving Standby by WakeUp pin and RTC Alarm&ContentTypeId=0x0107009D947151ED1E46c998F5DFE02DFA7356&DiscussionParentID=25694&Source=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Leaving Standby by WakeUp pin and RTC Alarm&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=191&ticket=ST-138079-C7VIndSq2t2U9zthKPaK-cas]link
2013-04-22 3:44 AM
Please see the official ST statement on this issue on the other [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Leaving%20Standby%20by%20WakeUp%20pin%20and%20RTC%20Alarm&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B]link regarding the same issue. Regards, ST.MCUTo give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
