TIM1 counting pulse from input signal help
Hello, I currently have a test bench project to carry out, so it's a drive motor that turns another motor, which generates an FCEM signal on my 3 phases, but the duration of the signal depends on the speed at which I'm turning, so I'd like to use tim...
Resolved! STM32G473 datasheet - upper limit on ADC external trigger period
Hi,maybe I don't know how/where to look, but I can't find any info why in datasheet for STM32G473 there is the max value for T_trig (external trigger period) in ADC timing characteristics (see the attached image). I several datasheets for several oth...
hepoun by Associate II
  • 4751 Views
Resolved! Environmental Impact of manufacturing STM32
Hello everyone,  I have a bunch of questions concerning the environmental impact of manufacturing a STM32  I'd like to see the impact according to as many criteria as possible from the following:  Contribution to the greenhouse effect Particulate mat...
Chall24 by Associate II
  • 5825 Views
  • 10 replies
Resolved! Connecting Arduino Portenta H7 to PDM microphone
Hello everyone,I am new to hardware programming so please excuse my basic question. Can someone please point me to the right resource to obtain data from an external pdm microphone (https://learn.adafruit.com/adafruit-pdm-microphone-breakout?view=all...
yshetty by Associate II
  • 3544 Views
Encoder problems STM32H743ZI2
Hello,I have a problem using the LL_TIM_ENCODERMODE_X4_TI12 on a nucleo_H743ZI2 development board. I directly read the counter register (TIM2->CNT for example ) to obtain the encoder value. I do however notice that even though the encoder is not rota...
Extracting rssi from scanned packet.
Hi,I need to get the RSSI of scanned BLE packet. So I'm using le_advertising_event .I found some one used the following code for that purpose.rssi1 = le_advertising_event->Advertising_Report[0].RSSI;but in the struct they mentioned that /* WARNING: b...
Kryptons by Associate II
  • 1436 Views
Resolved! RTC configuration of outpot ALRM
Hello st community,I work on stm32h7, and I use with RTC output alarmA, when the MCU power supple turned off, and RTC work with VBATT to wakeup some component with this signal, but this component needs any pules to wakeup and not woke up with first e...
dToub.1 by Associate
  • 5289 Views
Resolved! fast consecutive ADC Sampling for large chunk of data
Hi Everyone, in my previous posts i pretty much beat the bush around this subject and i did get some good supportbut i keep getting stuck with this issue.im using STM32H743ZI2 Evaluation board set to 32Mhzthe ADC is 16 bits and running on "fast chann...
shahaf321 by Associate III
  • 4054 Views
