FATFS STM32F4-Discovery
Posted on April 08, 2015 at 15:40Hi,I am trying to do a memory stick reading in the STM32F4-Discovery board.In order to test it, I am running the application example located in the following path:STM32Cube\Repository\STM32Cube_FW_F4_V1.5.0\Projects\...
lucas23 by Associate II
  • 2022 Views
STM32L151 failure accessing FLASH and EEPROM
Posted on April 08, 2015 at 17:04Hi, I am using the micro STM32L151 and I found that after programming the micro some of the micro have problems accesing FLASH and EEPROM.I can not program the micros again because it is not possible to read the FLAS...
ecatala by Associate II
  • 2144 Views
STM32 RTOS ERR
Posted on April 07, 2015 at 17:31The original post was too long to process during our migration. Please click on the attachment to read the original post.
herrusw by Associate II
  • 2715 Views
ADC in Dual Mode Simultaneously
Posted on July 22, 2013 at 15:27Hi everyones,I am stuying the example from STM32 libraries (ADC_DualModeRegulSimu). I understand how the whole program works but I need some information and I have few questions about this code confronting to my proje...
STM32F4-discovery DDS
Posted on April 07, 2015 at 15:43Hi. I try to make DDS. The code is below. The idea is to get new value of capture-compare register after Update event. This is done in the update interrupt. I have the following problems: 1) I do not see zero in the ...
baev_al by Associate III
  • 2660 Views
STM32F401RE-Nucleo LED and BUTTON's problem
Posted on April 07, 2015 at 18:27 Hi, I am trying to run a simple program on my new Nucleo board, I made this program in order to turn on and off the green led when i press the user's button (the blue one), #include ''stm32f4xx.h'' #include '...
Posted on April 07, 2015 at 18:22Hello, I am trying to run a simple program on my new Nucleo board, I made this program in order to turn on and off the green led when i press the user's button (the blue one), http://pastebin.com/9Q7KxsVA &sharpinclu...
STM32 with GPS
Posted on April 07, 2015 at 00:21 Hi there, I'm trying to parse some GPS data, to do this I want to limit the NMEA string coming from my GPS. I've found online that I can send the following to the Rx pin of my GPS to tell it to just send...
