Erroneous HSI default trim value in datasheet/CubeMX
Posted on February 11, 2018 at 13:59I found this by mistake.I posted a problem waking up from Stop Mode 2 via LPUART https://community.st.com/0D50X00009XkfHjSAJ.The problem started when I used CubeMX generated code to use 80Mhz system clock instead ...
Could you kindly fix the BUG in the SD card CubeMx v4.21.0
Posted on November 14, 2017 at 12:28Hello ST teamI'm writing to you because I'm working onSTM32F746ZGTx, but I have found the same BUG problem with the SD card in CubeMx version 4.23.0 library Firmware package STM32F7 v1.8.0.Before I was working wit...
JMJV by Associate II
  • 1867 Views
Up to which altitude does the STM32 work properly?
Posted on February 14, 2018 at 08:35I want to shoot it in about 20km altitude, but I have doubts about if the microcontroller still works under that low pressure. Does also anyone know the distance of the conducting paths?#altitude
Daniel H by Associate
  • 3653 Views
  • 10 replies
Serial over ST-Link USB on stm32F722
Posted on February 14, 2018 at 21:29Hello,I've developed a program reading and writing serial data using USART6 and pins 6 & 7 on GPIOC.  It uses DMA to perform the RX & TX and is working fine.  We thought we might be able to save some wiring effort...
Resolved! STM32H753BI stock
Posted on February 13, 2018 at 06:54ST, when would you expect these parts to be available ?How can I organise 2 units for my boards ?
T J by Lead
  • 1356 Views
STM32 RTC only updates after Reset
Posted on February 14, 2018 at 16:59Hello. I'm driving The RTC On STM32F4 Discovery and  I'm using STM32Cube for initialization. after everything, It only updates the value after a Reset. I don't know what the problem is. Can you help?Here is the co...
