Configuring interrupt pin using CMSIS
Currently I am trying to configure a second interrupt pin using CMSIS.SYSCFG->EXTICR[1] = (SYSCFG->EXTICR[1] & ~SYSCFG_EXTICR2_EXTI6)|(0b0000 << SYSCFG_EXTICR2_EXTI6_Pos); EXTI->FTSR = EXTI_FTSR_TR6; EXTI->RTSR = EXTI_RTSR_TR6; EXTI->IMR = EXTI_IMR_M...
Emper by Associate II
  • 2968 Views
Data convert in to zip format
hi i want to compress the text file in to .zip format and save this in to SD card, could you please tell me any one know about any library that available to do compressingi want .zip, i found some library to do gzipplease suggest me, Thanks in advan...
STM32F745 IWDG Refresh Problem when IWDG_RLR is less than 4
Dear All,I am trying to use IWDG for STM32F745 and I did actually. I used CT Cube MX to configure it. Prescaler is 4, Window is 4095 and RLR is 3. I checked clock configuration and IWDG uses 32kHz RC internal oscillator and count down from RLR. I exp...
TA1 by Senior
  • 1337 Views
Resolved! STM32 use SPI implement SWD?
I want to use SPI implement SWD protocol. Found this one enter link description hereIs there any advice you can provide detail?Have a nice day
YiKai by Associate II
  • 7480 Views
  • 15 replies
Using an STM32F030F4 20-pin for a battery powered application with just a low quiescent touch tensor (active high) for wake-up from low power stand-by on low-to-high and high-to-low sensor edges.
I'm considering an STM32F030F4 20-pin for a battery powered application. Might a low quiescent touch sensor (output high) in conjunction with the timers/functions onboard the chip be used to wake the chip from low power stand-by on the rising and fal...
How to see a graph from an array?
Hi all,I'm taking a lot of readings from the ADC, and store those reads in an array (reads[2000]).Is there a way to sohw a graph from the reads, using STMStudio or another program?
JAlca by Senior
  • 1381 Views
