I am having an issue doing the firmware update by OTA with my own code in BlueNRG-LP using Steval-IDB011V1 and BlueNRG-GUI app.
If I use the example BLE_Sensor_Demo + OTA_Reset_Manager I can update the firmware without any problem. I have followed the indications given in The BlueNRG-LP (over-the-air) firmware upgrade document (AN5463) and I don’t see any difference between m...
ARamí.1 by Associate II
  • 954 Views
Resolved! Pin Compatible Alternatives to STM32F765VIT6?
Due to the global chip shortages, we need to purchase a pin-compatible (LQFP100) version of the STM32F765VIT6. Since we don't need the 2k Flash we are looking at the STM32F7767VGT6, or the STM32F746VGT6. Both appear to have the same essential archite...
I want to generate 4 phase pwm for interleaved buck converter with independently controllable duty on each channel. I am using stm32f103 series mcu. I want to know if its possible with this micro controller .
I am told by that configuring a timer as master and others as slaves can generate multiphase pwm . but I cant figure out how exactly to set the configuration. I am aware its possible in few of the advanced MCU with HRTIM. But I want to use stm32f103 ...
Arg.1 by Associate II
  • 4057 Views
When will I get more info about this STM32U5 chip?
I've just noticed this upcoming STM32U5 - it looks amazing - and in LQFP48 package too!. FMAC, DC-offset filter for PDM microphones, inbuilt SMPS regulator. When can I see a Data sheet and reference manual? Mainly interested in seeing more info abou...
gregstm by Senior III
  • 1593 Views
STM32 CAN Bus not sending the messages
Dear sirs,I am trying to communicate through CANBUS an F407 and an H757 with external MCP transceivers.The problems I have are:-For the F407, If I set the mode to Loopback, I see with my external logic analyzer that it sends the message in the CAN1_T...
VCasa.3 by Associate II
  • 6783 Views
Stop mode and peripheral clocks
 Hi. I'm looking for guidance on entering and exiting Stop mode. L4, but probably applies more broadly. The RMs explain how to enter it, but I'm unclear on RCC effects.PLL oscillators other than HSI or MSI (depending on family) are disabled and desel...
DOCon.1 by Senior
  • 2605 Views
