AIS1120SX
Posted on April 08, 2018 at 18:01Has anyone developed STM32 code for the AIS1120SX accelerometer?-Bruce#accelerometer-ais1120sx*
Resolved! LIS3DH outputting unexpected data
Posted on October 16, 2017 at 14:15Hello,I am trying to log accelerations above 2g. To do so I parametrized the LIS3DH as following:- CTRL_REG0: 0x10- CTRL_REG1: 0x57 (100Hz + Xen + Yen + Zen)- CTRL_REG2: 0x00- CTRL_REG3: 0x40 (IA1 on INT1)- CTRL_RE...
LSM303AGR - Magnetometer: Perpendicular Readings
Posted on April 02, 2018 at 21:07Hi!I had a previous post asking how to interpret the values being drawn from the chips registers and I was able to get that working. (https://community.st.com/0D50X00009XkWYOSA3 )However, it only works as a 360 degre...
HTS221 accuracy and TN1218 question
Posted on May 06, 2017 at 22:23Hello,I'd like to ask you about opinion on accuracy of HTS221 sensors, both factory mounted on X-NUCLEO-IKS01A1 boards (powered by Nucleo board @ 3.3 V).I get quite surprising results from these sensors, compared to re...
Resolved! LSM303AGR self test always fails
Posted on March 29, 2018 at 23:41Hello, I'm using an LSM303AGR thru I2C, and after a little struggling, everythings looks fine. I can read any of the 6 axes with what seems to be the right values, and the read values react correctly when I tild my b...
Over-molding of LSM9DS1
Posted on March 22, 2018 at 08:57Hi, This question is regarding the e-packaging of the LSM9DS1 sensor PCBA Instead of packaging it in the plastic casing, We are planning to cover the PCBA with the overmolding material to cover the whole PCB includin...
LIS2DH12: High and Low Interrupt for all axis
Posted on April 02, 2018 at 21:52I'm currently trying to configure the LIS2DH12 sensor to enable high and low interrupt on all axis.My target is to implement a shock detection and therefore I plan to use all axis (x,y,z) and as well high and low thr...
Philipp D by Associate II
  • 3310 Views
