2025-11-11 11:55 AM
I recently switched to Mac Tahoe 26.1 and it seems since then stm32CubeMX 6.15 is not listing the contents of my Documents folder anymore. It doesn't seem like a rights management issue since
And yes, the folder does have contents and is not empty as shown in the screenshot from the file open dialog attached.
Anyone experiencing similar issues? How to come around that?
Best,
Oliver
2025-11-24 4:05 AM
Hello @SloBlo
Thank you for your valuable contribution.
Issue has been escalated to dev team under internal ticket ID 222404 .
I will keep you posted with updates.
THX
Ghofrane
2025-12-11 2:58 AM
Hello @SloBlo
For macOS the full disk access is required to load project files or install other packages from the file system. To enable full disk access for STM32CubeMX:
1. Go to “System preferences” and click to open “Security & Privacy” window
2. Select “Privacy” tab
3. Select “Full Disk Access” from the left panel
4. Click the checkbox to enable full disk access to STM32CubeMX
--> Hence, all folders will be visible.
This is detailed in the user manual of MX, particularly in section "3.1.1. Supported operating systems and architectures" (see attached screenshot from MX UM)...
2025-12-11 3:18 AM
Dear Ghofrane,
thank you for following up on this. Following your suggestion I can confirm that CubeMX can access Documents folder and I am able to continue working on projects in my preferred location on MacOS Tahoe.
2 remarks, though, to STM and anyone facing similar situation:
Regards,
Oliver
