2016-11-04 5:42 AM
In STM32Cube MX 4.17 I have set up an empty STM32L476 Nucleo project with and created code for the Low-Layer API. The parameters were:
SystemClock_Config() of the generated code starts with
void SystemClock_Config(void)
LL_PWR_SetRegulVoltageScaling(LL_PWR_REGU_VOLTAGE_SCALE2);
LL_RCC_MSI_Enable();
/* Wait till MSI is ready */
while(LL_RCC_MSI_IsReady() != 1)
LL_RCC_MSI_EnableRangeSelection();
LL_RCC_MSI_SetRange(LL_RCC_MSIRANGE_8);
LL_RCC_MSI_SetCalibTrimming(0);
LL_FLASH_SetLatency(LL_FLASH_LATENCY_2);
if(LL_FLASH_GetLatency() != LL_FLASH_LATENCY_2)
Error_Handler();
LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
The documentation (DocID024597 Rev 4, section 5.1.7 Dynamic voltage scaling management)
reasonably states that the FLASH latency must be set up
before the core voltage is changed.
However the function SystemClock_Config() does it the other way around. This may work under limited conditions…
#cubemx-flash-latency
2016-11-16 2:01 AM
Hello Kleier.hermann,
I want first to thank you for your bug reporting.
This help us a lot to improve our product quality.
I confirm that this has been solved, and will be available in the next cube release.
Kind regards
Sirma
2016-11-10 6:34 AM
Hi kleier.hermann,
Thank you for your feedback. The issue has been reported internally.-Syrine-2016-11-16 2:01 AM
Kind regards
Sirma
2017-03-31 3:13 PM
CubeMX v 4.0
STM32CubeL1 Firmware Package V1.6.0 / 01-July-2016
STM32L151
CubeMX is generating broken SystemClock_Config when HSE is selected to source other than MSI.
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5; is missing when ussing HSE(next code block below).
HAL_RCC_OscConfig uses RCC_OscInitStruct.MSIClockRange when RCC_OSCILLATORTYPE_MSI is set to RCC_OscInitStruct.OscillatorType
lack of inicialisation of MSIClockRange couses to error in HAL_RCC_OscConfig when calculating SystemCoreClock:
stm32l1xx_hal_rcc.c line 475:
(RCC_OscInitStruct->MSIClockRange have value: 0x10000000, viewed in debug)
SystemCoreClock = (32768U * (1U << ((RCC_OscInitStruct->MSIClockRange >> RCC_ICSCR_MSIRANGE_BITNUMBER) + 1U))) >> AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> RCC_CFGR_HPRE_BITNUMBER)];
this couses SystemCoreClock = 65536( but is should be i.e. 2097152) and in conseqence systick-load value to 64, what breaks the system
When MSI is selected for clock source everything is ok:
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
/**Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = 0;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
/**Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
When HSE is selected for clock source:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV3;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
Error_Handler();
/**Enables the Clock Security System
HAL_RCC_EnableCSS();
