  • 1756 Views
add lwip to cmake project for stm32h5
I need to add the LwIP component to a cmake STM32CubeMX generated project for the NUCLEO-H563ZI board.The LwIP component does not appear to be included in the STM32H5 package although the FreeRTOS component is.Is there a way to modify my top level CM...
Unable to open project
After a period of not touching the software.Unable to open a project.Tells me to update software.Existing software 6.9.2Software to update 6.14.1.Doesn't let me check the box.I am an administrator on this computer.How can I open the project and start...
ATfE support
Is there any plan to support creating ATfE-based camke projects in CubeMX?ATfE link: https://github.com/arm/arm-toolchain
JontyLi by Associate II
  • 765 Views
Using "BUILD_IN_SOURCE" false for CM4/CM7
Hi all,We would like to set BUILD_IN_SOURCE to false when building the two cores on the stm32h747 along with passing some other cmake options, but I don't see anywhere to change settings like that in CubeMX. Right now, we are just editing mx-generate...
chipchop by Associate II
  • 526 Views
software problem after and before update CubeMX and IDE
software problem after and before update CubeMX and IDEhi therecould you help me with this;after updating CUBMX to latest one 6.14.1, does not open the project automatically , even when i open it from IDE with existing project from CUB MX option , st...
Ali10 by Associate
  • 968 Views
Unable to open the project from a folder
I can open the project generated by STM32CubeMX normally, but when I try to open it through the folder, it becomes unresponsive and keeps lagging. Why does this happen, and what can I do to fix it?
lianghao by Associate
  • 507 Views
