  • 1757 Views
Cube MX and Flash
Posted on August 11, 2016 at 08:17Hey,i'm using CubeMX to generate code. In one of the examples is an EEPROM emulation (STM32Cube_FW_F1_V1.4.0\Projects\STM32F103RB-Nucleo\Applications\EEPROM\EEPROM_Emulation) which I want to use. My Problem is that ...
tekampe by Associate II
  • 1388 Views
STM32F051K6T6 hardfault with HAL and SPI
Posted on August 03, 2016 at 15:18 Hello, I've got a project build on custom PCB around STM32F051K6T6. There are a couple of other things on this PCB: ULN2003 driver, CD4511B driver , TLV73333 3.3V regulator and the main ''problem'' NRF24...
The system time
Posted on August 05, 2016 at 11:56I wanted to try out the CubeMX. I'm a bit stuck with some time issues. In standard peripheral I used system_get_time();What is the equivalent of this function in CubeMX?I found HAL_RCC_GetHCLKFreq(); that could be i...
CubeMx STML0 USB Hid Bug
Posted on August 04, 2016 at 10:36Hi everyone, I developed STM32L0 USb hid application with Cubemx,I send to data computer with usb hid interface.But I cannot send ascii zero(null )character.Other character send succesfully. For example my buffer li...
CubeMX and FreeRTOS : USE_RTOS set to 0 ???
Posted on July 29, 2016 at 16:10We use CubeMX .We have selected ''FreeRTOS''In the file ''stm32l4xx_hal_conf.h''  ''USE_RTOS'' is set to 0.See the following line:&sharpdefine  USE_RTOS                     0U It seems strange .the goal was to modify ...
gillou by Associate
  • 1054 Views
micro SD Card Programming on STM32F7 Discovery Board
Posted on July 28, 2016 at 19:10Hello,           https://www.youtube.com/watch?v=kRhF44v2ezMhttp://https//www.youtube.com/watch?v=kRhF44v2ezM https://www.youtube.com/watch?v=kRhF44v2ezM The initialization code was generated using STM32CubeMx  #sd...
Posted on July 28, 2016 at 19:06Hello,            https://www.youtube.com/watch?v=kRhF44v2ezM https://www.youtube.com/watch?v=kRhF44v2ezM The initialization code was generated using STM32CubeMx  #stm32cubemx #mmc #sd-card
