  • 1756 Views
Transmit Single Byte Using UART
Posted on September 02, 2016 at 20:13I am working on STM32F0. I am suing Uart HAL API to send a command to transmit data over UART which is     char *TxBuffer=''ABCD\n\r'';  int len = strlen(TxBuffer);  HAL_UART_Transmit_IT(&huart,(uint8_t*)TxBuffer...
anuj by Associate II
  • 7892 Views
stm32 USB VCP Receive problem.
Posted on May 18, 2016 at 07:26stm32 USB VCP Receive problem. hello. I need help. I use STM32F4 eval board. and I want use ROTS and USB_HS.my eval board has USB_OTG_FS and USB_OTG_HS. so I use USB_OTG_HS.I select in cubeMX, USB_OTG_HS's Exteranl Phy...
how to Clear RxBuffer in HAL_UART_Transmit_IT
Posted on September 01, 2016 at 00:12Hi,I have been wokring on STM32F030  Discovery.I have initialized UART. Whenever I send data from my PC to STM32. It adds the data into previous data. For example if I send ''123'' and next time I send ''456''. T...
  • 1528 Views
cube mx wwdg code generation bug
Posted on September 01, 2016 at 07:29Hi, I have a hands-on document about cube mx. I am trying to configure wwdg as my hands on document tell me. But there is a configuration bug I guess, cos after I enable wwdg it fires immediatly. (I have a bare p...
baycan by Associate
  • 1420 Views
Cubemx sdcard problem
Posted on August 31, 2016 at 13:12I am creating a project using Nucleo F401RE and cubemx and visualgdb. I've got a problem where there seems to be a clash between eeprom on spi and a 4bit sdio sdcard. I've got them working independently and together...
STM32CubeMX NAND STM32F2
Posted on June 21, 2016 at 17:51 Hello, I would report a strange issue in generating the low level driver for NAND. In particular there is a problem in function HAL_NAND_Address_Inc located in stm32f2xx_hal_nand.c: uint32_t ...
Bug Report: CubeMX 4.16 and IAR
Posted on August 10, 2016 at 11:08Hi to all, i use cubeMX and  stm32F401re, all work weel but tree days ago i update the libraries for STM32F4 family, lather this update i create a simple project with cubemx, when i compile whit IAR  i have this er...
antonioB by Associate II
  • 1135 Views
