  • 1757 Views
Resolved! HardFault_Handler() error: Why the generated code try to read address beyond valid memory range on 0xfffffffd?
So I tried to implement USB Host via USB_OTG_HS peripheral. I enable all the interrupts under NVIC setting (as I don't understand which one to choose). When I attach my USB stick, it is able to detect the USB, the user callback USBH_UserProcess() is ...
BParh.1 by Senior III
  • 10110 Views
Martin_S by Associate II
  • 1579 Views
STM32CubeMX crashes on launch with OpenJDK16
I recently upgraded from OpenJDK15 to 16 on my machine and noticed that STM32CubeMX now crashes at launch. The splashscreen shows up, but the main window never appears.​Here's a slightly abbreviated output:$ java -jar STM32CubeMX log4j user configura...
FUhl.2 by Associate
  • 2756 Views
Resolved! CDC_Transmit_FS() is giving me a headache (USB CDC Device mode)
Hello everyone and i hope youre having a great embedded morning.CDC_Transmit_FS() bricks itself when i check status of the ongoing transmissionis there any mechanism to know when a CDC_Transmit_FS transaction is finished?When i try to CDC_Transmit_FS...
Javier1 by Principal
  • 12612 Views
  • 12 replies
stm32h7 i2s dma transfer issue
Hello STM32 Community! My I2S dma transfer worked perfectly on stm32f7x in the past, but due to time critical calculations i just started to continue the development on the advanced stm32h7 system. I use the same code, same initialization procedure a...
akosodry by Associate II
  • 8750 Views
  • 13 replies
