  • 1764 Views
about "Generate Code" using STM32CubeMX software.
Hello.I am a stm32cubeIDE user in Korea.Thank you for creating useful software.​I processed "Generate Code" in the MX.It changed the code of Korean comments.I used the comment //.Please don't change the characters between // ~~~~ 0x0D.​This is normal...
Wings by Associate
  • 1191 Views
cubeMX generated project, compiling main.cpp using Makefile
Hi, I try to change compiling code method to Makefile. I'm using generated from cubeMX makefile with few changes. Everything works file when I compiling main.c file but, when I change file to main.cpp compiler print errors. I tried to fix this but, m...
JuniorSTM by Associate II
  • 4196 Views
Is it possible to use LQFP packaged STM32H75x with ethernet?
I am starting to design a simple testboard using STMH75x in LQFP package with ethernet. I don't want to design a BGA board.Is that possible. I tried same pins into with CubeMx as in Discovery board, but CubeMx did not fully accept those pins for ethe...
LMI2 by Lead
  • 1094 Views
Resolved! What does System clock and To Power mean???
1 . what does means System Clock in MCU?does it mean electronic device in a MCU that issues a steady high-frequency signal that synchronizes all the internal components?​I want the exact meaning of System clock.2 . what is To Power(MHz) SYSCLK ​in Cl...
MYu.1 by Associate II
  • 1492 Views
