2021-05-04 7:12 AM
Hello, I am designing with a STM32L011 (16KB) and setting up with STMCubeIDE. I require I2C, LPTIM,DMA and A/D with a small amount of program space for my actual program. The HAL however uses up all the flash space. Just adding the MX_ADC_Init() function uses about 2KB and overflows my last 10% of flash.
2021-05-04 7:30 AM
You can try to gear up optimisation settings, or check if you use the smallest library variant possible.
But otherwise, those are the perils of "convenience" frameworks, especially those trying to please everyone.
You could write your own libs, or use the "LL part (Low Level) of Cube/HAL.
While it does not come with the baggage of useless code, it is often incomplete and occasional buggy.
2021-05-04 7:30 AM
2021-05-04 7:43 AM
Thank you, optimizing for size has got me to 60%. Sometimes I can forget the obvious.
Cheers.
