  • 1756 Views
Resolved! [STMCubeIDE] V1.6.1 (using integrated CubeMX) does not properly generate initialisation code for SMBus peripheral
I am using an STM32F407 controller and have configured I2C1 as SMBus.However after configuration in the IDE, the initialization code generated for I2C1 is as follows:void MX_I2C1_SMBUS_Init(void) {   /* USER CODE BEGIN I2C1_Init 0 */   /* USER CO...
Nandan V by Associate II
  • 2700 Views
Updated MX to latest and get incorrect code generated...
I updated to the latest 1.7.0 for IDE and 6.3.0 for MX and when I regenerate configuration code using MX I get the following for ADC clock configuration.   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;   PeriphClkInit.AdcClockSelection = AD...
C Austin by Associate II
  • 2420 Views
STM32L4(96) Sample code needed for SDMMC+FATFS+DMA
I have spent a couple weeks trying to get this working, reading many ST threads about many quickfixes to get this to work on various stm32 chip versions. Ive had no real luck other than seeing some details about the SD Card like its size. Stm32CubeMX...
Tim12 TGRO is missing in cubemx.
In cubemx, the config of Tim12 TGRO is missing.Where in tim1, i can config it under Trigger Out Parameter. This feature is required by DMA request generator.I tried manually add some code to init this, but none of them work./* USER CODE BEGIN TIM12_I...
LLuca.1 by Associate II
  • 2022 Views
Resolved! STM32L4 USB BCD Bug
Hello, I use SensorTile.box with Stm32L4R9 MCU, CubeMx 6.1.1, Cube FW L4 V1.16.0I want to configure USB like a Virtual Com Port and it work's nice.But, when I set USB_OTG_FS->Parameter Settings->Battery Charging to Enabled CubeMX generate's such code...
qqAnton by Senior
  • 2167 Views
