  • 1756 Views
Problem during Server Connexion
Hi!I'm using STM32CubeMX 4.24.0 (I know, extremely old but I need this version to be able to follow along a course) and JRE 1.8.0_351 on Ubuntu 20.04.It seems the tool cannot find updates or other necessary STM32 Cube packages, with the following err...
CGalv by Associate III
  • 4718 Views
floating point and interrupt
Hi,i am using stm32F411 and generate programs with cubeMX.now I want to use the FPU in main and in interrupt context. Is it possible to use the FPU in interrupt context?I do not know how CubeMX generated programs handle the FPU context save within in...
rzong.1 by Associate II
  • 6151 Views
Resolved! STM32H7 ADC CLOCK PRESCALER NOT AVAILABLE
Hello.I have stm32h743vit6. After Cubemx 6.3.0, the adc clock prescaler setting is not available, it does not appear. Also, even if I open the adc channels, the adc mux is never active on the Clock Config page.In older projects (6.3.0 and earlier) ad...
AUNAL.1 by Associate
  • 2383 Views
[STM32L4R9I Discovery Kit]ADC+DMA problems.
I would like to construct an sampling system via using ADC+DMA method on STM32L4R9I official Discovery Board. I use STM32CubeMX to configure the peripherals and then compose the HAL code in Keil-MDK. The problem I met is ADC&DMA works well, but the ...
SLi.21 by Associate
  • 1360 Views
Why does my program always go into HardFault_Handler?
I just make a simple test. My cpu is stm32F303VET6,. Use Stm32cubeMx to generate a simple project with few lines of code, like:int main(void){ /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration-----------------------------------------...
plpc.1 by Associate II
  • 2182 Views
