  • 1756 Views
Resolved! Setup UART on NUCLEO-H7S3L8 Board
Hello everyone,im trying to send a simple "Hello World" via UART to my Laptop and read in the PuTTY Terminal on my on NUCLEO-H7S3L8 Board, But i tried everything, i cant revieve anything!!! Tried every UART/USART Port in the CubeMX. Nothing on my oth...
tobydgr by Associate II
  • 506 Views
Resolved! CubeAI generates wrong relative paths in CMake projects
Hi all,this issue is related to: https://community.st.com/t5/stm32cubemx-mcus/cmake-project-generation-with-cubemx-cubeai-fail/m-p/770680/highlight/true#M31054. , where it was solved by updating from STM32CubeMX V6.12.0 to STM32CubeMX V6.13.0. Howeve...
devjalx by Associate II
  • 591 Views
  • 4 kudos
Resolved! [Solved] CubeMx, run code generation from command line?
I have a project that uses different MCUs. 99.99% of the code is common for all, so I have different .project, .cproject and .ioc files for each, and use CubeMx to handle the hardware initialization.Currently, it requires manual building: Close the p...
FATFS Middleware for STM32U5 MCUs
Hi,I would like to create a project with CubeMX where I handle files on a SD card with FAT Fs file system using a STM32U5 mcu.When I select the STM32U5 MCU in CubeMX  the FATFS middleware is not available, while If I select other MCUs series like STM...
