  • 1756 Views
User authentication service maintenance on 12 March
Please note that the user authentication service will be under maintenance on 12 March at 5:30 AM CET (10:00 AM IST) for approximately one hour. During this period, some disruptions may occur. The impact is limited to versions earlier than STM32CubeM...
  • 228 Views
Resolved! Possible Issue in Cube MX 6.17
Dear all and ST Tech Support,I am writing to report a concerning inconsistency I encountered while migrating an older project to the latest version of STM32CubeMX (v6.17.0).Background: I recently reopened a project originally created about two years ...
TA1 by Senior
  • 556 Views
  • 4 kudos
Resolved! Startup code customization options feature request
On STM32Hxx and STM32N6 families I have faced a situation where I need to modify startup assembly code  (startup_stm32xxx.s) to copy code (.text) into ITCM or clear RAM/TCM areas, for clean data or to prevent ECC error (on STM32N6). But next time Cub...
Resolved! RMII STM32H743VIT6 Config
Hi all!I'm handling project which use communicate RMII TCP/IP. if i set up CPU clock is 200Mhz as picture 1, the system run OK, i can ping network but my system require CPU clock is 400Mhz. if i set up CPU clock is 400Mhz, the connection between boar...
