  • 1756 Views
arm_math library source lacks some functions
Hello all, I need to use some FFT functions. I have installed the CMSIS-DSP 1.16.2 and CMSIS 6.3 core as it was required from  CMSIS-DSP. Surprisingly, CubeMX did only a part of its job, namely it did not copy source files and did not add proper incl...
DmitryR by Senior
  • 409 Views
Resolved! STM32CubeMX 6.17.0 generated project lost <root folder>
  I have tried using STM32CubeMX 6.17.0 to generate an STM32F429 DISC1 project.The generated project opened in STM32CubeIDE could not be compiled unless I add <root folder> in Project -> Properties -> C/C++ General -> Path and Symbols, the source loc...
NEdom.1 by Associate III
  • 336 Views
STM32CUBEMX rendering bug serious
I am experiencing an issue in STM32CubeMX where all peripheral Configuration panels stay empty, while the Mode panels and System Core → Parameters render correctly.What I have already tried:Starting CubeMX standalone (not via CubeIDE)Creating a compl...
CDekker by Associate
  • 325 Views
Resolved! STM32C071FBP6 Pin muxing issue
I am using STM32C071FBP6N MCU TSSOP 20 pin package for one of our project.I am observing Pin_20 is muxed with lot of other pins like PB3/PB4/PB5/PB6. if i select PB3 as GPIO_Output using STM32CubeMx and generated a code. If i try to toggle the pin bu...
