How to import MDK-ARM project to STM32cudeide
Jacob3104
Associate II
1 ACCEPTED SOLUTION
Accepted Solutions
In this case, I think you should start the project from the .ioc file in this case.
Also, I may suggest you regenerate the project from CubeMX with IDE as a toolchain and unchecking the "Generate under root". This way any user code in the main.c will be kept (not sure about other files added by users).
Best Regards.
STTwo-32
5 REPLIES 5
STTwo-32
Hello @Jacob3104
I suggest you take a look at this post. It may be helpful.
Best Regards.
STTwo-32
Jacob3104
Associate II
But my MDK-ARM project based on STM32CubeMX (.ioc file)
Best Regards.
STTwo-32
Jacob3104
Associate II
i start the project from the .ioc file and also regenerate the project from CubeMX with IDE as a toolchain and unchecking the "Generate under root".
But after i generated, the project does not have anything.
Jacob3104
Associate II
This is the original file (SDIO+FATS) one, i want to import it.
