2020-07-12 12:13 AM
Hello community, I have a problem with new project creation, whenever I want to create a new project I come across this error: create minimal project failure: cannot read template source. reason: internal error
i know the problem which is having a space in my user folder name which i don't wanna change because it might mess my registry files.
so i'd like change the repository location to another place if it's possible.
thank you for having me.
2024-01-14 3:44 AM
2024-01-14 8:22 AM
New path to what? To your project or to the 'Cube repository'? If the latter - the old path is already written in the project config. Changing the repository path in the CubeMX/IDE settings won't help for existing projects.
What you can do: open the .project file in text editor and manually fix all instances of the old path. Usually in the <linkedResources> section.
2024-01-22 12:41 AM
This fix unfortunately didnt helped :/. So after all I did full reinstall of Cube programs and I make sure to save the appropriate program folders into a path without unsupported characters.
