2023-11-24 7:34 AM
I'm trying to enter standby (DDR off or on) on my custom board, containing a STM32MP151 and a STPMIC1B.
This is my STPMIC/suspend entry in the device tree of OPTEE:
&i2c4 {
compatible = "st,stm32mp15-i2c-non-secure";
pinctrl-names = "default";
pinctrl-0 = <&i2c4_pins_z_mx>;
//pinctrl-1 = <&i2c4_sleep_pins_a>;
i2c-scl-rising-time-ns = <185>;
i2c-scl-falling-time-ns = <20>;
clock-frequency = <400000>;
status = "okay";
/* spare dmas for other usage */
/delete-property/dmas;
/delete-property/dma-names;
pmic: stpmic@33 {
compatible = "st,stpmic1";
reg = <0x33>;
interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
status = "okay";
regulators {
compatible = "st,stpmic1-regulators";
buck1-supply = <&vin>;
buck2-supply = <&vin>;
buck3-supply = <&vin>;
ldo3-supply = <&vdd>;
ldo2-supply = <&vin>;
ldo4-supply = <&bst_out>;
boost-supply = <&vin>;
vref_ddr-supply = <&vdd_ddr>;
vddcore: buck1 {
regulator-name = "vddcore";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-always-on;
regulator-initial-mode = <0>;
regulator-over-current-protection;
vdd_ddr: buck2 {
regulator-name = "vdd_ddr";
vdd: buck3 {
regulator-name = "vdd";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
st,mask-reset;
vdd_ddr_1v8: ldo3 {
regulator-name = "vdd_ddr_1v8";
vdd_emmc: ldo2 {
regulator-name = "vdd_emmc";
regulator-min-microvolt = <2900000>;
regulator-max-microvolt = <2900000>;
interrupts = <IT_CURLIM_LDO2 0>;
bst_out: boost {
regulator-name = "bst_out";
interrupts = <IT_OCP_BOOST 0>;
vdd_usb: ldo4 {
regulator-name = "vdd_usb";
interrupts = <IT_CURLIM_LDO4 0>;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vref_ddr: vref_ddr {
regulator-name = "vref_ddr";
onkey {
compatible = "st,stpmic1-onkey";
interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>;
interrupt-names = "onkey-falling", "onkey-rising";
power-off-time-sec = <10>;
status = "enabled";
watchdog {
compatible = "st,stpmic1-wdt";
status = "disabled";
&pwr_regulators{
status = "okay";
/* USER CODE BEGIN pwr_regulators */
system_suspend_supported_soc_modes = <
STM32_PM_CSLEEP_RUN
STM32_PM_CSTOP_ALLOW_LP_STOP
STM32_PM_CSTOP_ALLOW_STANDBY_DDR_SR
system_off_soc_mode = <STM32_PM_CSTOP_ALLOW_STANDBY_DDR_OFF>;
vdd-supply = <&vdd>;
vdd_3v3_usbfs-supply = <&vdd_usb>;
/* USER CODE END pwr_regulators */
&vddcore {
lp-stop {
regulator-on-in-suspend;
standby-ddr-sr {
regulator-off-in-suspend;
standby-ddr-off {
&vdd_ddr {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&vdd {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&vdd_ddr_1v8 {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&vdd_emmc {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&bst_out {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&vdd_usb {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
&vref_ddr {
lp-stop {
standby-ddr-sr {
standby-ddr-off {
When I run
echo mem > /sys/power/state
I get the following message:
[ 47.699035] PM: suspend entry (deep)
[ 47.797158] Filesystems sync: 0.095 seconds
[ 47.807093] Freezing user space processes
[ 47.812012] Freezing user space processes completed (elapsed 0.002 seconds)
[ 47.817707] OOM killer disabled.
[ 47.820762] Freezing remaining freezable tasks
[ 47.827030] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 47.833040] printk: Suspending console(s) (use no_console_suspend to debug)
After this i am not able to wake, and the power supply rails are not at the expected levels:
VDDCORE is at 1.2V
VDD_DDR is at 0V
VDD is at ~300mV
VDD_DDR_1V8 is at 0V
VDD_EMMC is at 2.9V
VDD_USB is at 3.3V
Questions:
- How to debug this? Why could some rails still be enabled?
- Is only the device tree of optee important for standby?
- Do I have to disable peripherals explicitly in optee device tree when they are enabled in kernel?
2023-11-24 8:43 AM
some useful links (sorry if you already got it)
https://wiki.st.com/stm32mpu/wiki/Power_overview
STM32MP15x lines using low-power modes - AN5109.pdf
I'm not SW expert, but I guess all Device Tree should be aligned (or at least should not contain contradictory information).
2023-11-27 2:28 AM
I've read those wiki entries. When I enable 'trace and debug' I get the following log:
root@uptime:~# echo mem > /sys/power/state
[ 813.975319] PM: suspend entry (deep)
[ 813.989732] Filesystems sync: 0.012 seconds
F/TC:0 __clk_enable:1174 Clock 68 has been enabled
F/TC:0 __clk_disable:1187 Clock 68 has been disabled
[ 814.016977] Freezing user space processes
[ 814.023351] Freezing user space processes completed (elapsed 0.003 seconds)
[ 814.029120] OOM killer disabled.
[ 814.032077] Freezing remaining freezable tasks
[ 814.038682] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
F/TC:? 0 pta_scmi_ocall:178 Posting MSG message on channel 0u
F/TC:? 0 plat_scmi_clock_set_state:471 SCMI clock 8 disable
[ 814.176733] dwc2 49000000.usb-otg: suspending usb gadget configfs-gadget.g1
D/TC:0 pwr_scv_handler:56 PWR service: clear 0x1000000 at offset 0xc
F/TC:0 pwr_scv_handler:82 clr off c=1000000 => e0000000
F/TC:? 0 plat_scmi_clock_set_state:465 SCMI clock 13 enable
F/TC:0 0 __clk_enable:1174 Clock 140 has been enabled
D/TC:0 pwr_scv_handler:56 PWR service: set 0x1 at offset 0x28
F/TC:0 pwr_scv_handler:77 set off 28=1 => 1
F/TC:? 0 plat_scmi_clock_set_state:471 SCMI clock 13 disable
F/TC:0 0 __clk_disable:1187 Clock 140 has been disabled
F/TC:? 0 plat_scmi_clock_set_state:465 SCMI clock 8 enable
[ 814.264928] stm32-dma 48000000.dma-controller: Suspend is prevented by Chan 0
[ 814.270618] stm32-dma 48000000.dma-controller: PM: dpm_run_callback(): platform_pm_suspend+0x0/0x48 returns -16
[ 814.280710] stm32-dma 48000000.dma-controller: PM: failed to suspend: error -16
[ 814.288042] PM: Some devices failed to suspend, or early wake event detected
D/TC:0 pwr_scv_handler:56 PWR service: set 0x1 at offset 0x20
F/TC:0 pwr_scv_handler:77 set off 20=1 => 100
D/TC:0 pwr_scv_handler:56 PWR service: set 0x1000000 at offset 0xc
F/TC:0 pwr_scv_handler:77 set off c=1000000 => e1000000
[ 814.484889] dwc2 49000000.usb-otg: resuming usb gadget configfs-gadget.g1
[ 814.655228] stm32-rproc 10000000.m4: wdg irq registered
[ 814.659418] OOM killer enabled.
[ 814.662177] Restarting tasks ... done.
[ 814.688804] random: crng reseeded on system resumption
sh: write error: Device or resource busy[ 814.735200] PM: suspend exitSomehow DMA is blocking the suspend.
2023-11-28 12:25 AM - edited 2023-11-28 12:26 AM
I changed the device tree slightly:
&pwr_regulators{
status = "okay";
STM32_PM_CSLEEP_RUN
STM32_PM_CSTOP_ALLOW_LPLV_STOP
STM32_PM_CSTOP_ALLOW_LPLV_STOP2
//system_off_soc_mode = <STM32_PM_CSTOP_ALLOW_STANDBY_DDR_OFF>;
system_off_soc_mode = <STM32_PM_SHUTDOWN>;
Now the current drops to ~77uA when using 'shutdown -h now', and to ~1.2mA when using 'echo mem > /sys/power/state'. I looks like the echo mem method suspends to RAM, what I need. Unfortunately the method only works once, when I do another 'echo mem' after waking up from the previous one, the messages are there, but the current stays high, and after a couple of seconds the IWDG resets the processor.
If I enable the PM debugging, I get the DMA message again and the suspend is cancelled.
