STM32 MCUs
From FAQs to complete How-to articles, find useful articles on STM32 MCUs programming, troubleshooting, ecosystem, and product details.
Knowledge base articles
How to Control GPIO Pins with AWS Shadow
The following document will provide you with a brief overview of the basics of activating GPIO pins on the STM32U5 dev board to interact with a relay. This document will focus on the steps to configure the STM32U5 boards software to enable GPIO pins ...
How to implement USB Communication Device Class (CDC)
1. Communication of USB CDC in device mode For handling communication of USB CDC in device mode using legacy STM32 USB libraries are important 3 functions located in file usbd_cdc_if.c: CDC_Receive_xS - interrupt callback signaling received packet fr...
STM32WB stack update overwrite M4 application
Why does STM32CubeProgrammer erase/overwrite data (Cortex-M4 application) at flash address (0x08000000) during STM32WB Stack update over SWD? FUS can be managed only from internal bootloader or internal memory If SWD is used (means no-bootloader), th...
Connect the B-U585I-IOT20A board to Azure IoT Hub
Simple tutorial to connect the B-U585I-IOT20A Development kit to Azure IoT Hub.Introduction:In this article, we connect the B-U5U5I-IOT20A discovery board to Azure IoT Hub. IoT Hub is a cloud-hosted application that allows you to communicate with you...
Getting started with the STM32U5 IoT Node and Azure IoT and AWS
This article provides the necessary information for getting started with the B-U585I-IOT02A IoT Node with Azure IoT and AWS IoT Core 1- Hardware The B-U585I-IOT02A Discovery kit provides a complete demonstration and development platform for the STM32...
Slim.J by ST Employee
  • 2019 Views
  • 0 comments
Azure IoT Central B-U585I-IOT02A Notification Setup
Tutorial: Create a rule and set up notifications in your Azure IoT Central application for the STM32U5 board. Introduction:In this article, we use Azure IoT Central to monitor the telemetry sent by a device and create a rule that automatically invoke...
What are CRC features in STM32 MCUs?
1.  Cyclic Redundancy Check Cyclic Redundancy Check (CRC) is an error detection method for digital data based on binary division.CRC algorithm generates a fixed checksum code length. 2. What are CRC features in STM32 MCUs? The hardware CRC peripheral...
LauraCx by ST Employee
  • 4824 Views
  • 0 comments
Azure IoT Central B-U585I-IOT02A Secure Quick Connect
A simple guide to quickly and freely connect your B-U585I-IOT02A to Azure IoT Central 1. IntroductionThe following tutorial outlines how to connect the B-U585I-IOT02A Discovery Kit to Azure IoT Central with the X-CUBE-AZURE package using the followin...
Do I need TCPP01-M12 if I use USB Type-C™ at 5V only?
Do I need TCPP01-M12 if I use USB Type-C™ at 5V only?Consider that a defective or low-quality charger or cable is connected to your sink application and provides a voltage higher than negotiated, even if your sink application requests only 5V. Actual...
  • 760 Views
  • 0 comments
How to do an OTA update with STM32U5 and AWS
This article demonstrates how to integrate modular AWS FreeRTOS™ software with hardware enforced security to help secure updatable cloud connected applications. The project is preconfigured to run on the STM32U585 IoT discovery kit and connect to AWS...
How to connect my STM32 board to the X-NUCLEO-LPM01A
How can I connect my STM32 board with the X-NUCLEO-LPM01A (STM32 Power Shield)? There are several different ways to connect your STM32 board to the STM32 power shield, some more complex than others. In this article, we will discuss the simplest way t...
