2018-03-14 3:24 AM
Hy I want to reconfigure rtc from default to current time and date and this is the code but always code get stuck in function HAL_RTC_SetTime and this function callin in infinite loop __weak uint32_t HAL_GetTick(void)
{ return uwTick;}this is the code which i write to change time and date from default values.
HW_RTC_Init();
RTC_TimeTypeDef RTC_Time; RTC_DateTypeDef RTC_Date; RTC_HandleTypeDef hrtc; RTC_Time.Hours = 8; RTC_Time.Minutes = 25; RTC_Time.Seconds = 45; HAL_RTC_SetTime(&hrtc , &RTC_Time, RTC_FORMAT_BIN); RTC_Date.Date = 13; RTC_Date.Month = RTC_MONTH_MARCH; RTC_Date.WeekDay = RTC_WEEKDAY_TUESDAY;;
RTC_Date.Year = 18; HAL_RTC_SetDate(&hrtc , &RTC_Date, RTC_FORMAT_BIN); HAL_RTC_GetTime(&hrtc , &RTC_Time, RTC_FORMAT_BIN); HAL_RTC_GetDate(&hrtc , &RTC_Date, RTC_FORMAT_BIN); timeAr[0]=RTC_Time.Hours; timeAr[1]=RTC_Time.Minutes; timeAr[2]=RTC_Time.Seconds; timeAr[3]=RTC_Date.Date; timeAr[4]=RTC_Date.Month; timeAr[5]=RTC_Date.Year; timeAr[6]=RTC_Date.WeekDay;#rtc #i-cube-lrwan #murata-cmwx1zzabz-lrwan1-(ver1.1.1)2018-03-14 3:59 AM
See:
https://community.st.com/0D50X00009XkXuySAF
Specifically:
https://community.st.com/0D50X00009XkXuySAF#comment-174642
