STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4119 Views
memory address of BLE stack and how to read it
I want to see where BLE stack application saved in the memory through STM32_Programmer_CLI.exe application. Can anyone tell me the memory address of this BLE stack and how to read it by disabling read protection, I need commands. I successfully seen ...
SaM3 by Associate
  • 1511 Views
Sending strings to board stm32wb55
Hello! I am using BLE terminal app to send strings to my board stm32wb55 connected to my PC. On PC I am using the terminal Hercules to monitor UART. When I send a string from BLE terminal I don't see it on Hercules, but I can see all actions when fo...
Kolab by Senior
  • 2903 Views
Deleting flash memory breaks BLE connection on P-NUCLEO-WB55
I am using a P-NUCLEO-WB55 board and trying to delete flash from within a BLE app. I have used the p2p_server project as the basis for my project.(github.com/STMicroelectronics/STM32CubeWB/tree/master/Projects/P-NUCLEO-WB55.Nucleo/Applications/BLE/BL...
FFlet by Associate II
  • 1399 Views
GAP in SPI transfere on STM32WB55RGVx
Iam trying to setup SPI1 on STM32WB nucluo (STM32WB55RGVx), I made a configuration trough the STM cube and do some adjustments, the problem is that in every sequence iam trying to transmit with HAL_SPI_Transmit is a gap for couple of microseconds. Th...
DKope.1 by Associate II
  • 2635 Views
stm32wb55 ble pairing unsuccessful with windows 10 PC
Hi, i am trying to get familiar with stm32wb55 BLE functionality. As a part of it, i tried with Hear rate profile application example. when i run this application, i am able to pair with ST BLE Profiles mobile app successfully. How ever when i tried...
