STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
What is the correct procedure for FUS upgrade?
Hi,The AN5185 in "FUS upgrade" part says that FUS can be updated even with wireless stack installed. According to release notes start address for FUS should be 0x080EC000, but if a wireless stack is installed (for example BLE) this area will be locke...
ACham.3 by Associate II
  • 1061 Views
Scan BLE device and read RSSI
Hi everyone. I'm new to STM32WB and using P-NUCLEO-WB55. I wonder that how can i scan ble device near by and read their rssi. Can any body show me the way. Sorry for my bad english.
Tle t by Associate
  • 2472 Views
Resolved! Unable to set clock frequency above 32MHz
Hey guys,Im running into some issues with trying to set the clock speed of my stm32wb55 chip above 32MHz on my custom board.Here is my baremetal startup code that works using MSI as sysclkvoid __attribute__((naked)) Reset_Handler() { __asm__("ldr...
Adomin by Associate II
  • 2110 Views
Subghz phy pingpong example main.c is empty
hello, I downloaded Subghz_phy_pingpong example and i opened the project file.Then i opened main.c . it looks like in the picture below. i think its empty or did i opened in wrong way?
SSaya.1 by Associate II
  • 1289 Views
How to enable CFG_USB_INTERFACE_ENABLE in STM32CUBEMX?
I am trying to make the make the thread command line application on my custom board that communicates through the usb. In the WPAN configuration in CubeMX there does not seem to be an option that turns on CFG_USB_INTERFACE_ENABLE. Does anyone know ho...
NGama by Associate III
  • 2012 Views
