2022-01-03 9:32 PM
Hi
I need to show Arabic text which is updated from the main function on a wildcard. I bring the string from the backend through MVP to the view. Although I added related typography and wildcard ranges, the screen is blank. when I write English characters and use exp Verdana typography, the text is shown on the screen also it is ok when I write Arabic in the designer using Arabic typography.
I've attached my TOUCHGFX project and main.c file. I would be appreciated if anybody can help me through it cause I'm new to TOUCHGFX.
2022-01-03 11:08 PM
@Martin KJELDSEN I am so sorry to take your time. I used different fonts I searched over and over and could not find a hint. I was wondering if you could help me through this issue
2022-01-04 7:01 AM
Hi Zakba,
I'm not entirely sure what your problem is. You're trying to send a the wildcard part of s tring from your backend to your UI - And you're trying to represent that string (with the wildcard) rendered using an arabic font.
What type is this wildcard? Can you use a wildcard with your string if you just hardcode it in your ui and not receive it from the backend?
/Martin
2022-01-08 9:55 PM
Hi
yes, I can write Arabic text in the designer.
I want to use HWbuttons to fill a string character by character with Arabic font and then send it to the UI to show it. exactly like a keyboard but with HWbuttons, not touch buttons.
thank you very much for your answer master.
