STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! how does the stm32u5 work with lcd
There's a dev board with a lcd, but the U5 doesn't seem to have support for the same LTDC that that chips like stm32L4 or stm32F7 does.https://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-mpu-eval-tools/stm32-mc...
Badam.17 by Associate II
  • 3427 Views
Resolved! [SOLVED] After the instruction MX_TouchGFX_Init(), FATFS methods do not work as wanted (STM32F469I-DISCO)
When I'm using TOUCHGFX and FATFS together, I can create/write/read a file in my SD only if I do it before "MX_TouchGFX_Init();"f_mount(&SDFatFS, (TCHAR const*)SDPath, 0);f_open(&SDFile, "DIO.TXT", FA_CREATE_ALWAYS | FA_WRITE); //with TGFX this one g...
William F by Associate II
  • 1423 Views
STM32L4 and DCMI with 24bpp
Hi,I´ve done a lot of reading and testing...For some reason, its stated in both the datasheet and the DCMI application note that 24 bit per pixel formats are not supported. Trying to understand why...The DCMI is "stupid" in the sense that we only tel...
AJans.3 by Associate II
  • 1214 Views
How to add GPIO bindings to my VS Application?
I made a test project for my discovery board with TouchGFX.I needed the UI to react for a pin state change.I've seen tutorials, where a GPIO accessing function was added to the `main.c` file. Then it could be added as `extern "C"` from `Model.cpp` fi...
HTD by Senior III
  • 2920 Views
