STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
ST-link Utility is unable to program the external memory and throws 'File out of External Memory Range' error
I am trying to integrate STM32CubeMX and TouchGFX using IAR EW on STM32F769I-Discovery Board. I followed the instructions on the link below to configure the board:https://touchgfx.zendesk.com/hc/en-us/articles/360020208091 Then, I use ST-link Utility...
HKaur by Associate II
  • 3531 Views
DMA2D: incorrect transfer of JPEG image
Hello to everyone,I'm working on displaying JPEG files using STM32H745BIT6 chip. I successfully configured all peripherals (LTDC, DMA2D, HW JPEG decoder) and now I'm able to dislay JPEG data. At first JPEG decoder converts JPEG data to YCbCr data and...
_legacyfs_online_stmicro_images_0693W00000bjqvqQAA.png _legacyfs_online_stmicro_images_0693W00000bjqwKQAQ.png
Alex Gab by Associate III
  • 3910 Views
Resolved! touchgfx 1366*768 lcd flicker
https://drive.google.com/file/d/1slB_5LC5tWVdE61MoUpXk6XO0F--_Sts/view?usp=drive_link Hello,I use 1366*768 lcd in stm32h743iit6 with 50MHZ frequency and touch gfx. When I use value.setwildcard() and want to update a value on the screen it flickers ( ...
Zakba.1 by Senior
  • 5443 Views
STM32H747I-DISCO 16-bit Color Depth Problem
Hello,I have a stm32h747i-disco board. When I create a touchGFX project by using touchGFX designer template, it works perfectly. Its color depth is 24-bit and when I change color depth to 16-bit(RGB565), it fails.To change color depth to 16-bit, firs...
Gökhan by Associate III
  • 7312 Views
  • 12 replies
STM32H747I-DISCO screen horizontal artifacts
Hi,I recently purchased a STM32H747I-DISCO board from Mouser. As far as I know it was new and not used.After I flashed the ST demo application I noticed that the screen quality degraded over time and the white objects started to show white horizontal...
Mihai by Associate
  • 1492 Views
Resolved! Simulator crashes while Target runs. TGFX 23.0
Hello! I have a problem with simulator. When switching between screens (no animation) simulator crashes. The finalizeTransition function returns, after that the application ticks one time, and then crashes. Everything is executed normally on the targ...
MNema.1 by Associate III
  • 3838 Views
