2025-01-31 6:18 AM - edited 2025-02-02 10:04 AM
2025-02-03 3:11 AM - edited 2025-02-03 3:12 AM
Hello @simo zz,
I recommend you to look to these resources that can help you:
Thank you.
Kaouthar
Hello @simo zz,
Thank you.
Kaouthar
2025-02-03 7:46 AM
Thanks @KDJEM.1,
I think I have enough info to proceed.
Accidentally I deleted the content of the first post but the question essentially was:
#1) If it's possible to use the QSPI/OSPI has primarly flash. I am pretty sure this is possile after looking at your links and AN5050 and AN4760.
#2) How to set up XPI and External loader, but NUCLEO-HS73L8 has a setup for this purpose so I can look at it.
Thanks.
Cheers,
s.
