2015-01-27 11:07 AM
Good evening, i am a beginner in the stm32f microcontroller and i am trying to learn how to use the SDRAM embedded on the discovery board.I made a function which initialize the sdram gpio and timing characteristics but when i used the debugger the data is lost after a while.Perhaps somebody could explain me why. Thank you in advance !
void SDRAMInit(void)
/*-- GPIOs Configuration -----------------------------------------------------*/
+ SDRAM pins assignment +
| PD0 <-> FMC_D2 | PE0 <-> FMC_NBL0 | PF0 <-> FMC_A0 | PG0 <-> FMC_A10 |
| PD1 <-> FMC_D3 | PE1 <-> FMC_NBL1 | PF1 <-> FMC_A1 | PG1 <-> FMC_A11 |
| PD8 <-> FMC_D13 | PE7 <-> FMC_D4 | PF2 <-> FMC_A2 | PG4 <-> FMC_BA0 |
| PD9 <-> FMC_D14 | PE8 <-> FMC_D5 | PF3 <-> FMC_A3 | PG5 <-> FMC_BA1 |
| PD10 <-> FMC_D15 | PE9 <-> FMC_D6 | PF4 <-> FMC_A4 | PG8 <-> FMC_SDCLK |
| PD14 <-> FMC_D0 | PE10 <-> FMC_D7 | PF5 <-> FMC_A5 | PG15 <-> FMC_NCAS |
| PD15 <-> FMC_D1 | PE11 <-> FMC_D8 | PF11 <-> FMC_NRAS |--------------------+
+-------------------| PE12 <-> FMC_D9 | PF12 <-> FMC_A6 |
| PE13 <-> FMC_D10 | PF13 <-> FMC_A7 |
| PE14 <-> FMC_D11 | PF14 <-> FMC_A8 |
| PE15 <-> FMC_D12 | PF15 <-> FMC_A9 |
| PB5 <-> FMC_SDCKE1|
| PB6 <-> FMC_SDNE1 |
| PC0 <-> FMC_SDNWE |
GPIO_InitTypeDef GPIO_InitStruct;
FMC_SDRAMTimingInitTypeDef FMC_SDRAMTimingStruct;
FMC_SDRAMCommandTypeDef FMC_SDRAMCommandStruct;
FMC_SDRAMInitTypeDef FMC_SDRAMInitStruct;
volatile uint32_t ptr;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOF | RCC_AHB1Periph_GPIOG,ENABLE);
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FMC,ENABLE);
// GPIOB //
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;
GPIO_Init(GPIOB,&GPIO_InitStruct);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_FMC);
// GPIOD //
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOD,&GPIO_InitStruct);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FMC);
// GPIOE //
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_All;
GPIO_Init(GPIOE,&GPIO_InitStruct);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource2,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource3,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource4,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource5,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource6,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FMC);
// GPIOF //
GPIO_Init(GPIOF,&GPIO_InitStruct);
// GPIOG //
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_15;
GPIO_Init(GPIOG,&GPIO_InitStruct);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource8,GPIO_AF_FMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource15,GPIO_AF_FMC);
// init SDRAM
FMC_SDRAMTimingStruct.FMC_ExitSelfRefreshDelay = 7;
FMC_SDRAMTimingStruct.FMC_LoadToActiveDelay = 2;
FMC_SDRAMTimingStruct.FMC_RCDDelay = 2;
FMC_SDRAMTimingStruct.FMC_RowCycleDelay = 7;
FMC_SDRAMTimingStruct.FMC_RPDelay = 7;
FMC_SDRAMTimingStruct.FMC_SelfRefreshTime = 4;
FMC_SDRAMTimingStruct.FMC_WriteRecoveryTime = 2;
FMC_SDRAMInitStruct.FMC_SDRAMTimingStruct = &FMC_SDRAMTimingStruct;
FMC_SDRAMInitStruct.FMC_Bank = FMC_Bank2_SDRAM;
FMC_SDRAMInitStruct.FMC_CASLatency = FMC_CAS_Latency_2;
FMC_SDRAMInitStruct.FMC_ColumnBitsNumber = FMC_ColumnBits_Number_8b;
FMC_SDRAMInitStruct.FMC_InternalBankNumber = FMC_InternalBank_Number_4;
FMC_SDRAMInitStruct.FMC_ReadBurst = FMC_Read_Burst_Enable;
FMC_SDRAMInitStruct.FMC_ReadPipeDelay = FMC_ReadPipe_Delay_1;
FMC_SDRAMInitStruct.FMC_RowBitsNumber = FMC_RowBits_Number_12b;
FMC_SDRAMInitStruct.FMC_SDClockPeriod = FMC_SDClock_Period_2;
FMC_SDRAMInitStruct.FMC_SDMemoryDataWidth = FMC_SDMemory_Width_16b;
FMC_SDRAMInitStruct.FMC_WriteProtection = FMC_WriteBurst_Disable;
FMC_SDRAMInit(&FMC_SDRAMInitStruct);
// Start deliver clock to the SDRAM
FMC_SDRAMCommandStruct.FMC_CommandMode = FMC_Command_Mode_CLK_Enabled;
FMC_SDRAMCommandStruct.FMC_CommandTarget = FMC_Command_Target_bank2;
FMC_SDRAMCmdConfig(&FMC_SDRAMCommandStruct);
// Wait about 100uS
DelayUs(110);
// Precharge all the banks
FMC_SDRAMCommandStruct.FMC_CommandMode = FMC_Command_Mode_PALL;
while(FMC_Bank5_6->SDSR & FMC_SDSR_BUSY);
// Auto-Refresh command
FMC_SDRAMCommandStruct.FMC_CommandMode = FMC_Command_Mode_AutoRefresh;
FMC_SDRAMCommandStruct.FMC_AutoRefreshNumber = 8;
// Load Mode Register
FMC_SDRAMCommandStruct.FMC_CommandMode = FMC_Command_Mode_LoadMode;
FMC_SDRAMCommandStruct.FMC_ModeRegisterDefinition = 0x221;
// Program the Refresh Rate
FMC_SetRefreshCount(1297);
// Finish
for(ptr = SDRAM_BASE;ptr < (SDRAM_BASE + SDRAM_SIZE);ptr += 4)
*((uint32_t *)ptr) = 0x11111111;
The SDRAM_BASE is 0xD0000000 and the SDRAM_SIZE is 0x00800000.I am using the Keil Uvision V5.
