2014-11-06 6:07 AM
I am designing a PCB for STM32F301K8U6 (UFQFPN32 package) I connected the exposed pad area with the ground but currently I am not sure if its correct. There is not a word about what to do with it in thehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00093332.pdf
. I guess someone has an experience and could tell me how it should be connected. Thank you in advance. Lukas #stm32f3012014-11-06 8:01 AM
Hi Lupal,
What you did as action is correct. In the next datasheet release, this will be added.It is recommended to connect the exposed die pad to VSS.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
